I’m getting reverse retrims
Inverted Retrim.gh (25.8 KB)
This Retrim command seems quite capricious.
Any idea for a workaround ?
Trimming a surface in Grasshopper ? Someone ?
I don´t know what do you mean by “reverse retrims”. Maybe if you show me what you want as a final result it will be better.
But maybe this can help?
Inverted Retrim1.gh (26.7 KB)
I didn’t expect “Split Brep” to be the proper component here, but it does the job right, at least on this example.
Thanks !
It just didn’t make sense to me, because you already had the surface you needed as an input. I donno… Happy that it worked
I need certain edges to be untrimmed because they have to be fileted with others.
If filetting in Rhino wasn’t so iffy, I wouldn’t have to do all that stuff…
Ahhhh… and I feel your pain. The amount of magic tricks me and my team have to do when working with solids and so on… omg…
I’ve logged this bug, thanks for reporting.
https://mcneel.myjetbrains.com/youtrack/issue/RH-55373
– Dale
