Retrieving values from unconnected parameters
I want to read the name and value of all boolean toggles in a script and output it as a text file.
How do I retrieve the value of a component?
I have made an ugly hack using InstanceDescription, but can I retrieve the value in a better way?
I have the code:
private void RunScript(bool Run, ref object status)
List outputText = new List();
foreach(IGH_ActiveObject activeObject in GrasshopperDocument.ActiveObjects()){
if(activeObject.Name == “Boolean Toggle”){*
string str = activeObject.NickName.ToString() + " : " + activeObject.InstanceDescription.ToString();
outputText.Add(str);
status = outputText;
And get the output
myBooleanToggle : One locally defined value…
True
myOtherBooleanToggle : One locally defined value…
False
The output is want is:
myBooleanToggle : True
myOtherBooleanToggle : False
Cast your “activeObject” to the proper type “Grasshopper.Kernel.Special.GH_BooleanToggle” so you can use the .Value property:
    List<string> outputText = new List<string>();
      if(activeObject.Name == "Boolean Toggle"){
        Grasshopper.Kernel.Special.GH_BooleanToggle toggle = (Grasshopper.Kernel.Special.GH_BooleanToggle) activeObject;
        string str = toggle.NickName + " : " + toggle.Value.ToString();
Works beautifully, thanks
