Retrieving the index values for the "True" Values on a list
I have produced a list of True False values and I need to retrieve the index values of the True results.
Unfortunately “Item index” doesn’t accept boolean data. Any smart ideas on how I can do this?
Thanks in advance x
Use the Series component to generate an index list the same size as list of true/false values. Then use the Cull Pattern component to cull the index list.
If you want further explanation, post your code.
-Kevin
Thank you :smiley: You’ve saved me from an hour of frustration! :pray:
The posted solution by Kevin works perfectly well. But just for your continued reference, the component that does what you want is “Member Index” (Sets > Sets > Member Index).
Solution provided by @daniMunthali is definitely better, I need to make an effort to use the sets components more frequently.
-Kevin
