Retrieving text dot's "display text" in c#
Dear all,
I am trying to retrieve text dot’s “display text” in C# component. Below is the code that I was working on, and I am having trouble in getting display text from the object. Any help will be much appreciated.
var objArr = Rhino.RhinoDoc.ActiveDoc.Objects.FindByObjectType(Rhino.DocObjects.ObjectType.TextDot);
foreach(Rhino.DocObjects.TextDotObject rhObj in objArr)
var txt = rhObj.Geometry.UserData; // how to retrieve “display text”?
Print(txt.ToString());
Best,
W
Answering my own question… For just in case someone wants to know.
var rhObjArr = Rhino.RhinoDoc.ActiveDoc.Objects.FindByObjectType(Rhino.DocObjects.ObjectType.TextDot);
foreach(Rhino.DocObjects.TextDotObject rhObj in rhObjArr)
  var objRef = new Rhino.DocObjects.ObjRef(rhObj);
  var dotObj = objRef.Object() as Rhino.DocObjects.TextDotObject;
  var txtDot = dotObj.Geometry as TextDot;
  var txt = txtDot.Text;
  Print(txt);
No need to recreate the reference.
      var txtDot = rhObj.Geometry as TextDot;
      Print(txt);
Thanks much!
