I’m currently trying to build a consistent surface using two side surfaces and a bunch of guide curves. NetworkSrf does a good job. But on a specific part of the connection it creates an ever so small fold. Is there a good approach to iron this fold out?
Hello - well, this is the problem with NetworkSrf - it makes a dense surface - lots of control points - so that matching it up for tangency along an edge can be technically correct but look bad since the tangency or curvature points are very close to the edge.
Given the curves you have I’d build this as a Loft and then MatchSrf to the straight surfaces. problem_PG.3dm (176.6 KB)
