Resize a Project
I’ve modeled and rendered a product. First of all without paying attention to proper measuring sticks etc. just to see what it would look like in general. Is there now a way to scale the individual elements to the correct size?
Hello - use the Scale command. Select all the objects you want to scale - presumably everything, make sure nothing is locked or hidden - and then snap a base point and referenece point where you know the correct distance should be between the points - then type in the correct diistance and Enter.
