Is there a way to set or change the default camera position directly in ShapeDiver — not through code, but within the platform interface itself?
When you are editing a model on the ShapeDiver platform, there are settings for the camera here (per camera), which at the bottom also offer fields for camera position and target.
Perhaps this helps.
Please check the following help center article, in particular the section called “Editing the position”.
