Rescale Blockdefinition with Grasshopper
Im trying to edit a block-geometry (in this case the two sections i baked before) which I draw first in Rhino and defined it as a Block called HEA 200. I draw the HEA 200-Block 1m long and want it to scale along a Curve i set in the crv component. So far so good.
Now I cant edit the scaled Block in Rhino cause of the warning below.
Is there any possibility to scale a block inside Grasshopper and be able to edit the scaled block afterwards?
Non-uniform scaled blocks cannot be edited at this time with Rhino.
I believe that the new Block editor plugin can do this: https://www.food4rhino.com/en/app/block-edit-new
