Request: UseEntireWidthForTopBand Wonky Alignment
Hi McNeelies,
When using Rhino.Options.Advanced.UseEntireWidthForTopBand = False the alignment of the upper tabs/borders look a bit wonky. Maybe it would be possible to have the top bands be fully aligned (third image below)?
UseEntireWidthForTopBand = True
UseEntireWidthForTopBand = False (aligned/proposal)
Thanks and happy summer :smiling_face_with_sunglasses:
Best,
Anders
Edit: @Gijs maybe you would know if this is possible?
I don’t know, but I suspect it is not very easy to do, since the space for the menu needs to be truncated.
Hey @AndersDeleuran,
Thanks for the suggestion, but it is not quite feasible to move the panels area into/overtop the menu bar. There would also not be a workable solution for Mac either.
Only thing I could suggest that we could do is remove the panel title, but that is not really ideal to not know at a glance what panel you’re on.
No worries, thanks for the reply @curtisw :slight_smile:
