Could the version and SR of Rhino be added as a TextField/AutoText so you can put it in a title-block next to the filename? @Gijs
I don’t see how that would work. As soon as you open it in another version, that field will update
Having the Rhino version and SR in the “hard-copy” or PDF-print is very relevant if you are working in a studio (or other corporate setting) where fx some projects need to be completed in say Rhino 8 fileformat but all new projects are Rhino 9 and the Blocks shared by all projects are in Rhino 7.
When you perform an “Audit3dm” the Rhino version + SR used for creating the file is one of the informations you find, but not many people are using Audit and a TextField could be part of your template -and maybe respect a SaveAs in other versions if in Notes?
Ideally I would as a user like to know the Rhino version and SR of a Rhino-file without the need for Audit3DM and a TextField could put it in a PDF next to FileName and ModifiedDate.
Tim
man. 19. okt. 2026 kl. 23.47 skrev Gijs de Zwart <notifications@mcneel.discoursemail.com>:
Thanks Tim
I logged it as RH-99681 Text field for the file’s Rhino version
