Hi McNeelies,
The Rhino.UI.Controls.Slider seems like a perfect functional fit for writing custom Grasshopper remote control panels (i.e. it works natively with float/negative domains and has a value handle/dragger one can double click to set the value). It would be nice to set the styling a bit though (e.g. colors, stroke weights, font, height, corner radius), but if that’s not possible it would be great if you could make the Rhino 8 styling the same as in Rhino 9 (i.e. not as tall and much less bombastic left side color):
Rhino 8:
Rhino 9:
(And yes, I will absolutely start learning Eto Drawables. But all in good time and such
Thanks and best,
Anders
Ps. It would be awesome if you exposed more of your custom Rhino Eto controls in RhinoCommon!
