Request: An option to not display objects being transformed during commands such as Move, Rotate, Orient, Orient3Pt, etc. The problem is when transforming dense meshes and point clouds it can be difficult or impossible to the the target point because it is obscured by the highlighted dense mesh wires or points. Even if the objects are on a layer which is turned off or is hidden, as soon as the objects are moved they become visible. I understand that this is the very desirable behavior in most circumstances, but it is can be a signficant problems in some situations. That is why Iām requesting an option, not a change in the default behavior.
This has been discussed previously, for example Selection of MOVE OBJECT to ANOTHER OBJECT and display question
