Request: Numerical rotation relative to cursor position
Maybe this doesn’t bother anyone else, but I wish the rotate command acted relative to the position of your cursor when typing in a number value - similar to the way offset acts. I constantly am typing and then retyping a number with a negative when working on the fly.
For example your center is the center of the orange circle, and your start angle is the yellow line. If you type 18 and your cursor is in the red half, it would set the rotation to 18 degrees counter clockwise, if your cursor is in the blue, it would go clockwise.
This isn’t the biggest deal as I could train my brain to recognize that all rotation is moving in the same direction, but it’s been 7 years of using rhino and old habits die hard. It would be nice not to need to constantly type the negative - could be a toggle on the rotation command that switches it from absolute to relative so no existing functionality breaks.
Nice idea if it’s only effective after two points are picked.
