Request - Nudge to Rotate
Request - The abilitly to nudge objects to rotate about a selected point, analagous to Nudge. This would probably need to be a command, named something like RotateNudge.
The roation would be about a selected point. There would be three levels of rotation using the arrow keys and page-up page-down keys. Tapping a key would cause a “small” rotation of a user specified amount, with three amounts available using the shift and ctrl/cms keys. Each pair of keys would cause a rotation about a different axis, analagous to how Nudge works for translation.
Reason for the request - I import 3D models (dense meshes and point clouds) from photogrammetry and need to orient the models in Rhino. I use Nudge extensively to fine tune the translation part of the positioning. For rotations I use the Rotate command and type in a small angle, then wait to see where the model winds up. Then start Rotate again, type in a small angle, etc.
Hi @davidcockey
In V4 someone created this Vbscript. It works for me in V7. Drag and drop the rvb file into Rhino. Extract the attached tb file from the zip file it should have all the commands on blank icons. Once you set a center on your object use the icon to repeat rotating like a nudge key would do. You could also assign NudgeRotateForward to a hotkey.
Don’t know who wrote it but it’s a nice thing to have.
SetNudgeRotate
NudgeRotateForward
NudgeRotateBack
The above are the commands on the toolbar and commands that will get it working once you install the .rvb file if you want to make your own toolbar.
RM
NudgeRotate_V4.rvb (3.2 KB)
NudgeRoate_V4.zip (538 Bytes)
