Hi, I know that saving mesh settings is an old request and I read that you can create scripts to save settings for future use. I don’t know how to create scrips, but may be someone has something to share that I can tweak a little to fit my need or guide me to create simple script that I can associate to a button.
Lately I’m exporting meshes with very different settings for Z-Brush or Modo and having some presets could be greatly appreciated.
you might start with button macros or use the script provided by @Helvetosaur in [this thread] (Python Export obj files - set polygon density variable). You can customize the settings used in the GetOBJSettings
function for your needs and save different scripts which you can then put on different buttons.
c.
Thanks @clement and @Helvetosaur, it seems I have what I need now
I opened the .py file in wordpad and copied the script into a button command window, added
! -_RunPythonScript (
Pasted here
I’m not sure if this is the way to do it, but it’s enough for me, I’ll create one ore two more buttons with different settings.
Joaquín
