Request for Match command: With option MatchTo=PickPoint allow selecting a point on a closed curve, not only a point on an open curve. The open curve limitation is needed when matching to curve end, but should not be needed when matching to a point elsewhere on the curve. Example situation where this would be used:
It looks fine on my side, and for your reference.
@jessesn My request is for the Match command, not the BlendCrv command you showed in the video.
The Match command does not allow selection of a closed curve as the target for the option MatchTo=PickPoint.
Sorry, this is my fault.
Thank you for your report, and it is a known request on the list
RH-78519 Match: allow closed target curves
Another vote from me, as well. ![]()
