Request. Layout import "with options"
Hi again,
This is a small request. I frequently import layouts from other files, and it would be very helpful to have buttons or options to “Select All” and “Deselect All”… even a search function. At the very least, a “Deselect All” option would make the process much easier.
thank you
Hi mutarq,
There is a feature request that is about to go into Rhino 9 in this regard.
RH-50557 ImportLayout - Select All / Clear All
You can verify in the next an Rhino 9 WIP release by using the get issue state and inputting the issue number RH-50557
