Request for Installation of Two Free Korean Fonts in Shapediver
Dear ShapeDiver Team,
I hope this message finds you well.
I am currently developing a configurator in which end users input their own text, which is subsequently converted into geometry. As the text is generated dynamically based on user input, the corresponding fonts must be available on the shared server. I would therefore like to kindly request that the following two freely available Korean fonts be added to the Rhino 7 shared system:
1. SF망고빙수 (SF_IceMango)
  • Designer: Noonseori (눈서리)
  • License: Free for both personal and commercial use; modification and redistribution are permitted, with the sole restriction being the resale of the font file itself.
  • Source: 활자 깎는 노인 : 네이버 블로그
2. 고산자 (Gosanja)
  • Publisher: National Geographic Information Institute (국토정보플랫폼) in collaboration with Sandoll
  • License: Free for both personal and commercial use; distributed as a public font without usage restrictions.
  • Source: http://map.ngii.go.kr/mi/emapMain/emapIntro01.do
Both fonts are freely available, and their licenses permit unrestricted public use. I would be grateful if you could review the respective licenses and, should everything be in order, proceed with adding them to the shared server.
Please do not hesitate to contact me should you require any further information or documentation regarding the fonts.
Thank you very much for your time and assistance.
Best regards, Edgar
Please send links which allow us to directly download the font files, or attach them directly.
Hi Alexander,
Thanks for your help!
I have attached the font files for both fonts directly to this post. Please let me know if everything is in order.
Best regards,
Edgar
SF망고빙수.zip (518.9 KB)
baroemap_gosanja_font.zip (19.0 MB)
We deployed the fonts, please try whether they work as expected.
I am experiencing an upload timeout error when trying to upload a Grasshopper file that uses Korean fonts.
  • Error Message: “The checking process for your model timed out for an unknown reason.”
  • Model uuid: a244efe5-e6ba-432a-9839-1e8e7359cba0
  • Model guid: c21e38b5-f397-432c-a1d4-9671efde478c
Details:
  • The upload works perfectly fine without any issues when I use standard default Windows fonts (like malgum_Korean gothic).
  • The timeout error only occurs when I apply the specific 2 Korean fonts to the Grasshopper file. It seems like the system is having trouble processing or rendering the specific Korean font files during the verification step.
Could you please help me resolve this font compatibility/timeout issue?
Thank you!
I created a minimal example using both fonts:
gosanja.gh (9.1 KB)
It works as expected when uploaded to ShapeDiver:
Could you please share a minimal example from your side that causes the issue?
I confirmed the model works properly in Rhino
Howerver, the same issue occurs when i upload the GH file to ShapeDiver.
If I use standard Windows system fonts, the file uploads successfully and works fine.
I suspect some characters in the requested Korean fonts might have self-intersecting curves. Could this be causing the issue?
Should I try using a different Korean font that doesn’t have any self-intersecting curves?
Thanks
As I mentioned in my message above, I could create a model with those fonts and upload it to ShapeDiver without issues. If you are still having trouble uploading, it would help if you could create a minimal definition that I can test and reproduce the problem with. Could you share such a definition?
Thank you for your support. I tested the file by breaking it down into smaller components step-by-step, and I can confirm that it now works properly!:grinning_face: :+1:
Regarding the fonts, would it be possible to request the installation of additional Korean fonts in ShapeDiver? Please let me know if there is a specific process or requirement for requesting new fonts.
Thanks again for your help.
