Is it possible to remove the Orange Error when a User Text Key is not present on a Model Object? I am using the ‘Filter Content’ component to break up my data streams and most of the objects do not contain all possible set of keys. I think the warning is good, but making it my component orange is also makes my cluster orange when there is no real issue.
I’ve discussed this with @kike, and we both feel that a warning on the User Text component is the most appropriate message level for this issue (i.e., a key/value not being defined on an object). That said, if there is significant feedback or concern, we’re happy to revisit and discuss further.
…to be honest I am not sure if I like this either because my script clearly isn’t working and there is actually no way to figure out why this is happening,. The way that a warning percolates outside a cluster is not consistent for components.
The only way to figure out why a null appears is to hover over the cluster and see the small snippet
But this is also not good when the snippet might be huge and lets be honest, I am not going to understand much when I work with 100s of clusters across dozens of files.
Hmm. If the cluster color is not being transferred correctly and/or consistently, then this sounds like a bug that I will need to investigate. I have created a YT ticket (RH-91101) to track this issue. If you have other examples of clusters which do not transmit the proper warning/error color to the cluster, please attach them here. Those would be useful in testing.
