While using Clipping plane, sometimes it is best used with fill,
but then it is also very useful to uncheck the Fill to be able to see inside the object.
At the moment it requires going to Display-Mode to toggle this.
it will be very helpful to have this checkbox in Properties so it is toggleble when Clipping Plane is selected .
Hi Akash - the Display panel shows the current viewport display mode - clipping plane fill behavior can be controlled on the fly from there - is that good enough?
Yes of course… An oversight on my part.
Apparently I never scrolled down to the bottom of that panel.
[UI wise, it would have made perhaps sense to have it all in one place.]
thanks a lot
Akash
