Report Component Issue
I am currently using Karamba3D with an active Educational license, which is correctly recognized in Grasshopper. However, I cannot find the Report component described in the documentation (section 3.7.4 Report).
My license panel shows the following information:
Karamba3D version: 3.1.51222.0
License type: Educational (Zoo / Zoo Cloud)
License is active and recognized
The Report component does not appear in the Karamba3D tabs, and searching for “Report” in Grasshopper does not return the component.
Hi, you need to activate “View WIP Components” in the menu to see this component: 2.3 The Karamba3D Menu | Karamba3D v3
Thank you, I have now located it.
Further to this, could you please advise whether there is a way to display the minimum and maximum envelope of a shell in the model view under load case combinations? At present, the model view appears to show only the individual combinations rather than a single envelope representing the overall minimum and maximum results.
I would appreciate your guidance on whether this functionality is available and, if so, how it can be enabled.
Also further to my comment before, the report is giving me this error: Solution exception:Could not load file or assembly ‘Microsoft.Extensions.Configuration, Version=3.1.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60’. The system cannot find the file specified.
