Hello everyone,
I am working on a workflow where I want to locally modify an area of an existing surface (for example a sphere). Conceptually, I have a target surface (eg sphere), and I would like to replace a local region of it with a custom deformed surface, while keeping the body watertight
Currently my idea is to do a kind of “ surface replacement”:
I project a reference surface on the target geometry.
I modify this reference surface into the surface I actually want to integrate (transformed surface).
I scale the region of the reference surface slightly to get some tolerance buffer.
I trim out the corresponding area from the target surface using the scaled surface.
I use lofting between the edges to connect the modified surface and the original body.
I try to rebuild it into a surface
This almost works, but in the end I always end up with very small gaps along the transition, most likely due to tolerance.
surface_replacing.gh (4.1 MB)
I think i could transform it into a mesh and then use ShrinkWrap to fix it, but thats to computationally.
Performance is important to me. I deliberately only want to manipulate a small region of the object, because the final models will become larger and more complex. I already tried more approaches such as:
converting everything to dense point grids and then deform the points
locally increasing mesh resolution (for deformation workflows like Mesh by Color)
Both worked conceptually but became too computationally expensive.
Do you guys have an ideas for:
a robust approach for replacing or locally deforming a surface region
ideally something that is not extremely computationally heavy
Any guidance, best practices, or example definitions would be highly appreciated.
Thanks!
