ReplaceEdge Help needs updating
The Help entry for ReplaceEdge needs updating to include Mode=SelectCurve option.
Current V8 Help for ReplaceEdge: Rhinoceros Help - Trim | Rhino 3-D modeling (mcneel.com)
ReplaceEdge
Toolbar Menu
Surface Tools|Surface
Edge Tools >
Replace Edge|
The ReplaceEdge command re-trims the selected trimmed surface edge with a line, extensions of the adjacent edges, or a curve.
Steps
  • Select surface edges to delete.
Command-line options
KeepTrimObjects Determines whether or not the original trimming objects are retained.
Mode ##### ReplaceWithLine
Replace the edge with a line between the edge end points.
ExtendSideEdges
The two surrounding edges extend.
The edges must meet within surface boundary to give successful results.
SelectCurve
Edges will be replaced using the selected curve to retrim.
Hi David - here is what I see in the latest -
Is that what you mean?
Missed it.
