Replace Text for multi ghpython
Example : I want change all text “123” to “abc” for multi window ghpython, it took too much time if I open 1 by 1 for replace it. Do we have another way for change 1 time.
If you want to edit the exact same components in sync, you can put them in Cluster.
If you want to change the contents of your existing GHPython, you can save it as ghx instead of gh and open it in a text editor for batch conversion.
ghx
Thank you too much, you save my day.
You can use the replaceGHPythonString function I posted over here (last code block):
Thank you for that.
