If I create the text ‘a’, then double click to edit and replace with ‘A’, the text itself does not update, it will still be lowercase. In the properties window, it will show as uppercase. If the text is edited to ‘B’, that will be uppercase, but if I change it back to ‘A’, it will still read as ‘a’.
Interestingly, if I edit it in the properties window, it still does not update, but now the text in the properties window will also not update.
Thanks,
Sam
