Hi
I’m trying to use very simple “replace path” definition but got stuck.
I would each closest sphere to be renumbered like each circle below, where am I wrong?
Thx
Replace path problem.gh (204.7 KB)
Hi
Thx
I see you renumbered as I was looking for but can’t see what you did…
Thanks a lot !
Will have look as soon as I’m back at the office
Exchanging the inputs of closed points component
Hmmm, HS Kim example works fine, but I just changed the inputs with new shapes.
Definition is quite the same in structure, but doesn’t work, I’m lost again.!
Naked edges doesn’t fit the same number as rectangular curves, why in this case?
Canvas%20at%2015%3B32%3B46|690x490 Replace path problem bis.gh (105.7 KB)
Your curve parameter is empty.
Many thanks , it works perfectly, I just took time to understand how it goes ^^
