Replace Cylinder with Custom Bamboo Geometry from Rhino
Hi everyone,
I’ve just recently started using Grasshopper and I’m learning as I go.
I’m currently working on a script that distributes cylinders along a curve and scales their height based on their distance from a reference plane. This setup works perfectly.
Now I’d like to replace the cylinder with a bamboo stalk I modeled in Rhino, which I reference using a Geometry component. I want to keep the same behavior:
• The height of each bamboo should match the distance between the curve and the plane
• Bamboos should be placed along the curve
• Each bamboo should be scaled in height accordingly, just like the cylinders
I’ve tried using Scale NU, Bounding Box, Distance, etc., but it’s not behaving the way I expected.
I’m attaching:
• A screenshot of the version that works.
What’s the correct way to make this substitution while preserving the scaling logic?
Any help is truly appreciated — thank you!
Could you internalise geometry (right click on the source curve and surface components) and upload the .gh file?
1.gh (729.4 KB)
Hi, thanks for your help! i’ve now internalised the curve and the surface (and the bamboo geometry too, if needed)
The code you posted has none of that :interrobang: It doesn’t match the image of code you posted. :frowning:
I apoligize, i may have misunderstood the previous message. I’m now attaching the Grasshopper file related to the image i posted earlier.
2.gh (13.7 KB)
2+.gh (745.7 KB)
a bit boring to use a curve in an parallel plane? all distances are equal?
…still I hope my file answers your question?
when Surface and Curve are Not in parallel planes : should the bamboos still be normal to the surface or to the curve or still in z…
would you still ask for the distance in z or for the closest point?..
Unfortunately I can’t open your file — I think it was created with a newer version of Rhino than mine (I’m using Rhino 7).
Actually, the distances will vary, because my idea is to manually rotate the plane in Rhino. That way, the bamboo heights will change depending on how I move the plane along the Z axis.
I’ve been able to make this work using a simple cylinder created directly in Grasshopper. But when I try to use a more complex geometry — like a bamboo stalk modeled in Rhino — it no longer works, since the cylinder and the Rhino geometry don’t have the same kind of inputs. That’s where I’m stuck.
I can open your file in R7 but it’s extremely slow :interrobang: Freezes my machine.
it´s not fast here: 1800 copies are scaled nonProp and placed
the bamboo is haevy …
After locking the solver to open the file, I reduced the count from 1800 to 114. Always a good idea until one is sure the code works.
That may be the real problem because it’s still slow.
Also, ‘Scale Z’ factor is always the same so doing it many times is pointless. ( @Atlas_Atlas )
yes pointless for now but he wrote the intention is to change that - rotate the plane, make the distance vary
tried changing the order of Scale nonProp and orient - does not help the speed
I understand. Still, there are several problems as you noted. For one thing, there is no “plane”; I guess @Atlas_Atlas means “surface”?
Thank you again for your patience — as I mentioned before, I’m just starting out with Grasshopper.
I tried your script and I’m attaching a picture of the result: the plane behaves exactly as I intended.
However, my issue is that along the curve, instead of my bamboo stalks, there are cylinders. I’m probably doing something wrong.
Images of code are useless compared to posting the actual GH file :bangbang: :bangbang:
3.gh (740.4 KB)
The wire is missing from Divide Curve ‘Points’ to the target XY Plane.
VERY HEAVY :bangbang: The GH file is 740+ KB :interrobang:
thank you all, now it works!
This is the same code except for two things:
  1. The white group creates the bamboo by revolving a curve.
  2. A plane is used instead of a surface. This creates a slight difference because Project to Plane uses the plane’s Z vector instead of “normal” Z.
The GH file is much smaller. It’s still relatively slow to render (not seen in the profiler) because of the detail in the bamboo geometry, which is completely lost at this scale. The original bamboo geometry was a “Closed Brep” with thickness, so was worse.
bamboo_2025May6a.gh (29.5 KB)
