Repeat Process
Dear Sir
I need help. I have done my script with
one value (draft), i want to repeat to another several value (drafts)
Would it be possible for you to help me.
regards
amit
Hull.3dm (422.7 KB)
test1.gh (32.7 KB)
test1_re_V1.gh (209.3 KB)
Thank you sir for your quick reply.
But i need result for different different draft. Like in my example i have show 8 m draft i.e. Z distance.
And i am getting centroid (Y distance) of all section at that particular draft.
Same way i want to get result for different z distance, 8, 13, 16…n numbers etc .
**Condition : 1) Draft (z value ) will vary. 2) At every Z distance (x=0, y =0, z=varies) Hull (ship) will rotate transversely. **
Result : At every draft get centroid of all sections (stations).
Now, you have three branches of section profiles, and you can get the centroids of these sections…
Yes i have, but only at single draft.
What will happen, If draft is in series ?
Like i have shown result of 8 m draft, below that i need result of 13m draft and below that 16m and so on.
Please try if possible.
I don’t know much about the shipbuilding and don’t know what you mean by “draft” either, anyway the result you’ve made is not different from mine?
test1_re_V2.gh (214.7 KB)
Draft means Z coordinates,
Any way, i will check latest file and get back to you.
