Repeat command by right click
When I right click to select a command that I have just used not all show up.
This worked perfectly in rhino 7 but is not working as I believe it should in V8 on the mac.
Most of the recently used commands are there but not all. In particular the re scale in 2d command.
If I use re scale 2d command it does not show up when I right click to repeat it.
hi @gurney1 I could not reproduce the behavior you are describing. If I run Scale2D I can repeat the command afterward succesfully.
Pls run _SystemInfo in Rhino and post back the results.
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13002, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Commercial, build 2024-03-12
License details: Cloud Zoo
Apple macOS Version 13.6 (Build 22G120) (Physical RAM: 32GB)
Mac Model Identifier: Mac13,1
Language: en-GB (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
LG UltraFine (2560 x 1440 @ 60.00Hz)
Thunderbolt Display (2560 x 1440 @ 60.00Hz)
USB devices
MOSART Semi.: 2.4G Wireless Mouse
SanDisk: Extreme 55AE
LG Electronlcs Inc.: LG UltraFine Display Camera
LG Electronics Inc.: LG UltraFine Display Controls
LG Electronics Inc.: LG UltraFine Display Audio
Apple Inc.: Apple Thunderbolt Display
Apple Inc.: FaceTime HD Camera (Display)
Apple Inc.: Display Audio
Apple Inc.: Apple Watch Magnetic Charging Cable
3Dconnexion: SpaceNavigator
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.5.24072.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.5.24072.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24072.13002
hi @gurney1
So say you run these 5 commands:
Box
Circle
Line
Rectangle
Scale2D
and you then right click in the viewport and hold until the popup menu appears, how does the most recent commands list look at your end?
Ok so if I type the command scale 2d it then does repeat when i right click.
Normally I will go the transform cascade menu and pick 2d scale. If you you do it this way it does not appear when you right click to repeat it. It does in rhino 7.
I think lots of commands are doing this if it is chosen from a menu rather than typed in the command line.
Also when I right click to repeat and choose which ever command I am looking for it often will not repeat the chosen command and something else will appear in the command line.
This is really odd, I will ask internally if someone is able to repeat, as I still cannot.
hi @gurney1 so far we could not reproduce that behavior here either.
Just one additional question. In that list I see File Import listed on top. When I have that, and I run Scale2D, it will push that command to the top of the list. Is that happening at your end as well?
As far as am aware what ever command you last use will be at the top when you right click.
That is how it has always worked in V7.
It seems a bit random as I did try opening a new file and the scale 2d was there in the list after using it.
I’m sorry I cannot provide more help on this issue right now. It would be helpful if you find an exact pattern of when this happens and clear steps how to reproduce.
Sure I understand.
I will do some more investigation.
Thanks for taking a look.
If I’m not mistaken, this is the same report as: Some commands are not showing in Recent Commands
Yes thats the same problem I am having.
