Hi everyone. I’m using ladybug to get the test point that fit my criteria
and i would like to reorganize to data tree so that every branch is set by a z factor domain (0-4, 4-8, 8-12… etc) right now it is organized like this.
reorganize branches.gh (1.4 MB)
it does not work without the EPW file
ISR_Tel.Aviv-Bet.Dagan.401790_MSI.rar (149.8 KB) copy the EPW file address to the path component
Thank you for your help.
Your model won’t work without the data file that drives it:
Can you internalize the outputs of the ‘radiationAnalysis’ component?
Looks exactly the same to me - no data:
There is no data coming out of the ‘radiationAnalysis’ component. I’m done with this one now. I won’t look again. Good luck.
HS_Kim
December 29, 2017, 3:39pm
7
Hi.
Is this what you want to accomplish?
reorganize branches_re.gh (1.0 MB)
Can you please explain why I can’t see any data in your version either?
i’ve added the epw file because there is no way to internalize the date in the sun analysis component
My request/suggestion was to internalize the OUTPUT of the ‘radiationAnalysis’ component. Everything after that is standard GH components so surely there must be a way? This is SOP (Standard Operating Procedure) for posting models to the forum. Does it really need to be re-explained every single day?
Asking questions and getting answers is what this forum is all about. Although people are generally very helpful, there are things you can do to improve your chances of getting good and quick answers. Below you will find some suggestions, but don’t think of them as rules and especially don’t think of them as guarantees.
1. Choose a descriptive title for your post
Don’t title your question Help! or I have a problem or Deadline tonight!, but actually describe the problem you are having.
2. Be s…
HS_Kim
December 29, 2017, 4:12pm
12
I don’t understand what you want…
thanks kim, it works great.
