I have a series of circles which I created using a rectangular grid, with circles at the centres and used Select Boundary to isolate the one in the wedge shape. There are 266 of them. I then created a rectangle and divided it up to create 266 points. I then wanted to connect each point with a line so that it creates a line of cables from the wedge shape to the rectangle. E.g. The top let in both would connect together and so on. As it stands the lines cross over because the ordering is wrong. Is there a way to reorder or should I recreate the wedge shape points to try and match the ordering of the points in the rectangle?
Rhino File: Point Order.3dm (184.1 KB)
Grasshopper File: Point Order.gh (16.3 KB)
Thanks for any help.
