Hi All!
im strugling with the face order in a mesh, do you know any way for reordering the faces in a linear way??
reorder mesh faces.gh (5.4 KB)
Hi All!
Quick way as order is same as Z
Or use a plugin (Nautilus here but Stripper could have some tools)
I used 2 points to define an edge that gives the direction
I think this approach is better as it will work with all orientations.
P.S. : Most of time order of mesh faces has little importance. Topology meaning relations matters. A number has little impact. Whatever the number of face the mesh is the same!
P.S 2 : this mesh has 2 points that are not the same. Welding it could improve things (topology, links …)
