Rendering software for jewellery design
Editing itself directly not per se, but Cycles knows how to render panorama that can be used as equirectangular environment input for skylight. So you’d use a HDRi image you like, but you’d want to add some elements, like lighting, or block parts. So you set up planes/surfaces, give them shaders as you want them, position a camera at 0,0,0 correctly oriented and render a 360° panorama and save as EXR.
So at some point we can have that capability in Rhino, but not at this very moment.
Here some old crystals by @DavidRutten using Raytraced (Rhino integration of Cycles in upcoming V6, can be tested in Rhino BETA): Material preview crystals
/Nathan
