How do you make the text in dimensions renderable just like in old Glory 3ds Max.
Thanks
Thanks
I’m not sure what ‘old glory’ means but here are some suggestions…
If you are using the Rhino Renderer or Brazil for Rhino, check the annotation post effect in the post effect section of the render window. Or use the free Neon real time render plugin and they’ll show up if annotations are checked in the Display panel while Neon is active. I prefer the latter since Neon will anti-alias them nicely. You can also explode dimensions and text and then construct planar surfaces if needed but that’s a bunch more work if you have a lot of dimensions.
