I have this problem when rendering using Vray
The rendered image is broken in several locations even though the size of the image and the dpi are set to a higher setting.
the attached image shows such breaks
GPU or CPU rendering? Parallel camera? Rhino 6 or 7WIP?
Which Vray version are u using? is it saved from VFB or IPR?
CUDA so I believe it uses both CPU and GPU and as for the Rhino version it is 6
You could try the CPU mode. In cuda mode the GPU is used for rendering. It’s only a basic test and I hope finally someone from the chaosgroup can help further.
