Rendering issues with the Shadow
Hello everyone, I am having some issues with a render of a chair. In ‘Rendered’ display mode the shadow looks fine, but then when I render it, the shadow comes out a bit strange, and it makes the chair appear to be floating. I can’t just take a screenshot of the rendered display mode because I need the transparent background. Any help please? Thanks in advance!!
Looks like your ground plane is shifting..
Any hidden geometry anywhere that may be causing it?
You can force the location of the ground plane in the ground plane panel by using the manual options and setting it to snap to the bottom of your part.
Thanks for your reply,
Yes, there was some hidden geometry, but I arranged the ground plane and the render is coming out as I wanted it to.
Thank you!!
Recently in 8 a groundplane bug was fixed. Either in 8.20 or 8.21.
