HELP!
although I use command " VisGuessLenseShift ". It doesn’t help anything. My rendering result is still different to what I want in viewport.
HELP!
Are you using standard Rhino perspective view, not 2point perspective?
Try to set the Vertical Tilt manually:
Sorry, my vray is 2. I’m still not updated. But thank you.
In my experience GuessLensShift rarely worked and I had to guess and enter the number manually anyway. It should be similar and you should try to start with numbers like +0,5 and -0,5.
Jonas
where can I enter number?
exactly, GuessLensShift works. But I don’t know why, after I load gi_irmap_high.visopt, it doesn’t work anymore.
