Renderimages show edges of Nurbsfaces
Verry frustrating…
Renderimages show some edges of the nurbsfaces. This faces are created with BlendSrf-command, they are closed. The model is created in R8. Older projects don´t show this problem (I tested same rendersetup in R8 with them). The third image show the problem in raytraced viewmode too. I try to switch off nvidia-denoiser - no success. Graphic is uptodate.
  1. rendered
  1. shaded
  1. raytraced
My specs:
Rhino 8 SR34 2026-7-21 (Rhino 8, 8.34.26202.13001, Git hash:master @ 885b468dd95d813ba5ae29900b6f269eccce92e0)
License type: Commercial, Build 2026-07-21
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.29
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 7-2-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.74
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-2-2026
Driver Version: 32.0.16.1074
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Users\Frank\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.34.26202.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.34.26202.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.34.26202.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.34.26202.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.34.26202.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.34.26202.13001
Thank´s for help!
Frank
Are they closed? Are the project mesh settings NOT aligning joined edges? I mean rendering is generally designed to smooth over not-quite-perfect stuff, kinda need a file to try to see what’s going on.
What are your settings for Raytraced?
Options > View > Display Modes > Raytraced
Options > View > Display Modes > Raytraced > Objects > Surfaces
Thak you for the reply. All faces are closed. I didn´t change the raytraced mode options but both “tangent” options were set “on”. I turn it to “off” - no changes.
Frank,
Could you select two or three adjacent surfaces, export selected, check the problem exists in the new file and then post the file here? Inspection usually works better than guesswork.
If the exported file doesn’t show the problem, I’d try checking the original to see whether any of the surfaces are duplicated. Multiple surfaces occupying the same space can create these edge artefacts.
Regards
Jeremy
Hi Jeremy,
I did as you told: The new file works fine. I will check the rest.
Thank you.
Ok, I found some issues and rebuild them. Crazy thing, never had had this before.
At least I find out the real reason: I had some faces in the closed nurbsmodel with a different material. After rearanging and joining all faces the rendering is ok. after selecting some faces to define another material the error appears again. Now I separate these areas so they stand alone with an other material.
before
after
