Rendered view with wallpaper in layouts
I have been preparing a set of drawings for issue, and decided to add some wallpaper to the rendered view, to make it look a bit more realistic. This works ok, but my rendered view in the layout only shows the wallpaper when the detail is selected. When the detail is de-selected, it disappears. Does the render wallpaper setting not apply within the layout space?
Here is how it appears in the detail:
Here is how it appears in the layout print:
Can anyone tell me where I’m going wrong?
Does placing the picture in the layout space behind the detail view work ? (never tried)
I haven’t tried putting images in layouts before, either. A quick try, it doesn’t appear to be possible to send the image to the background, so in the print you don’t really see anything other than the background.
Cabin Type 1 test.pdf (3.7 MB)
Oh, that’s right display order can’t be set for picture… and just checked, neither for the detail views.
Sorry, I don’t have any other idea to make it possible inside Rhino.
Does anyone from McNeel have any comment?
Hi Frank- Here, the wallpaper shows if I set it in the detail view, active or not,
but indeed it does not show in the print.
try this
BackgroundBitmap command
raster output
