Rendered surface
Hi there,
My surfaces in rendered mode are showing up with geometric likes like so once I zoom in. Is there a property I can change so that this is just a flat volume?
Hi @Alexandra_Garcia_Jim
I take it, that you mean geometric lines. Without seeing the file and your SysInfo, my guess is that you are either very far from the world origin or have a massive scene. If you are far from the world origin, try moving alle the geometry closer to 0,0,0 and see if that works. If it’s a very large scene, you can try to hide geometry not in view. It could also be a graphics card driver issue, but you’d have to run the SystemInfo in Rhino and post the result here for any help on that.
HTH, Jakob
