Hi!
I just updated to the latest version of Rhino WIP (6.0.16348.9381, 13/12/2016) and I found some problems while drawing objects in Rendered mode.
While I move the viewport (only the camera is moving) there are multiple gray lines crossing the mesh/brep:
When I stop moving it, the lines dissapear:
This is my graphic card:
Regards,
Thanks. I am aware of this. I will try to have a fix in before the next WIP is released.
I made a YouTrack item: https://mcneel.myjetbrains.com/youtrack/issue/RH-37244
-David
This has now been fixed. It should be available in the next WIP.
Thank you David, I will check it
brian
(Brian Gillespie)
5
RH-37244 is fixed in the latest WIP
