Rendered mode: all objects gone black
all objects were white at first
then I set up some materials through layers (wood as an import, metal from internal library). Worked.
But when Rhino crashed, in rendered mode the material of all objects went full black.
I removed all material then, but even adding materials, all objects stayed deeply black:
Saved as another file.
Now all objects are white again, as expected.
Setting up the materials again …
Thank you for the report, I created a YT issue for it.
https://mcneel.myjetbrains.com/youtrack/issue/RH-49806
This should be working a lot better in the latest RhinoWIP. Please give it a try.
