Rendered Diamond Ring
Good design :slight_smile:
What is its material?
Hi there and ty, unfortunately I stopped to use KeyShot in 2019 (way too expensive).
I am unable to open the keyshot files (.bip) since I don’t use their app. Anymore.
I was able to get some info for you about the initial material color I started, I hope it helps.
R-255 G-226 B-155 or R-FF G-E2 B-9B RGB HEX- FFE29B
Sorry not been able to give you more details.
All the best, always.
Hi Sciensman, thank you. The material for this hammered finish eternity band is Metal > Polished > Polished Gold from the Material Library. Polish: 85%. Let me know if you have other questions.
probably, you used some colorful lights that affect the gold, because it has now an appearance similar to copper.
I used these lights…
Lights
Some other renders…
Yes, It is now the appearance of a hammered golden ring
Good luck :slight_smile:
Thank you!!
