RenderBlowup
Dear Mcneel Team,
I have a question about the RenderBlowup command. In my case, it doesn’t work on Mac or Windows in Rhino v8.
I’m a lecturer and curator of first-year students at ETH in the architecture department. I’m looking for the most efficient render workflow in Rhino. We’ve been very happy with the results so far, but now that we’ve a workflow to find the best 2-point perspective model alignment, we’d like to crop the render. After researching, I haven’t found any supporting information on the RenderBlowup command.
According to your documentation, the RenderBlowup command renders a selected area of the current viewport in the render window at the resolution specified in the Rendering panel.
In the attached screenshot, you’ll see that my custom resolution is now astronomical, but it still renders in the viewport resolution. Could you please help me determine the correct direction to take?
Thanks a lot,
Best regards,
ivan
systeminfo:
Rhino 8 SR30 2026-4-13 (Rhino 8, 8.30.26103.11002, Git hash:master @ 3ad61623b0ac4561e2f13265580c56a9f50596d8)
License type: Educational, build 2026-04-13
License details: Cloud Zoo
Apple macOS Version 15.7.4 (Build 24G517) (Physical RAM: 16GB)
Mac Model Identifier: MacBookAir10,1
Language: en-US (MacOS default)
.NET 8.0.14
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1
Color LCD (2048 x 1280 @ 60.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftDataDetection.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/iab/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/libSubstanceImporter.dylib
/Users/iab/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/libsubstance_ogl3_blend.9.dylib
/Users/iab/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/libsubstance_linker.9.dylib
/Users/iab/.rhinocode/py39-rh8/libpython3.9.dylib
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_heapq.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_ssl.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/libssl.1.1.dylib
/Users/iab/.rhinocode/py39-rh8/libcrypto.1.1.dylib
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_socket.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/math.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/select.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/array.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_struct.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/binascii.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/zlib.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_bz2.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_lzma.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/grp.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_bisect.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_random.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_sha512.cpython-39-darwin.so
/Users/iab/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_datetime.cpython-39-darwin.so
/Users/iab/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/SubstanceImporter.rhp “SubstanceImporter” 2.0.7.0
/Users/iab/Library/Application Support/McNeel/Rhinoceros/packages/8.0/BeamBoxMap/0.8.13+26560/BeamBoxMap.rhp “BeamBoxMap” 0.8.13.26560
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.30.26103.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.30.26103.11002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.30.26103.11002
