when selecting Render from the drop down Render menu, well it’s just not right
Hmm - I do not see that here - so the top part is never filled in, the rendering quits/finishes?
Hi Pascal, no the render window size is huge, out of proportion, and the object is to the bottom, and not fully in view, have attached full screen recording, hth
yes didn’t think to check there, maybe needs setting as default to 800 x 600, bit confusing seeing that so big and out of proportion
@pascal got some materials and other things just rendering in a blue colour instead of the correct material colour, should I create new topic ?
Blue vs Red is being worked on already, no need to create separate thread for that.
Yes.
