When rendering the render window will be rotated or the object will be off in the distance. Sometimes it will be both.
This does not happen every time. It is very random. After several attempts the window will be OK but may go back to a rotated view at any time. I have contacted McNeel in Seattle and they can’t seem to solve the problem. Any help will be greatly appreciated.
Did you email a file to tech@mcneel.com? I don’t find any records of emails with you searching under the address you used for the forum account. I’d like to see one of the files if possible saved when the rotated view issue is happening. One guess/question I have based on your description is if you are using a 3D connexion device. I’m wondering as well if the viewport shows the same orientation when you close the render window.
