I have forgotten a command and cant seem to find it.
I need to patch a small portion of an image. Consequently I need to re render just a very small portion of a selected view.
The renderinwindow command only seem to render at viewport resolution.
Can anyone tell me the command to render in window but at the output resolution?
Yes…you are correct , however the patch doesn’t seem to be rendering at the output size. It seems to be rendering at the viewport resolution. Sorry to be a nuisance.
I just checked it on a new file.
Again at this end on my PC “Renderpreviewinwindow” is giving me a patch rendering, but it is at viewport resolution not output resolution.
ok something is screwy here. Now I think you had it right the first time with renderinwindow. I just tested here in rhino5 and that is what is working for me. renderpreviewinwindow only gives the low res render.
but you still don’t get the high res patch with renderinwindow?
This is amazing! This is a lifesaver on time. I wish I knew about this command forever ago. How come it doesn’t come up as an available command in the drop down section of the command prompt?
