Render text to screen increases the Z Location of the camera incrementally
Hi
I’m having a similar problem as described here
The last comment from the author confirms that the “Render text to screen” component is causing the issue. I’ve uploaded an example causing the problem. A quick way to build up the z value of the camera is
change the slider - action in rhino - change slider - action in rhino.
Is there a fix to this or a way to avoid it? Many thanks.
Also, the screen I’m using is 3840x2160.
buggyScreen.gh (4.6 KB)
@andheum
Hi, not sure if you saw this :slight_smile: (sorry for the spam if you did) Is there currently a way to fix the camera zooming out?
Many thanks
PS: Love your plugins!
