Hi, I have downloaded the evaluation of rhino 6 and have tested the renders. It is taking a very long time even on the simplest model.
Set at 1600 x 1200, good quality, studio lighting with skylight on.
windows laptop (lenovo P50), i7, ssd, quadro m1000
Have I got someting set wrong for the renders?
Was much quicker rhino 5 with brazil.
Thanks
Fred_C
April 22, 2020, 1:49am
2
Hi. In V6, please run the SystemInfo command and post the results here.
Thanks Fred,
See below -
Rhino 6 SR24 2020-3-19 (Rhino 6, 6.24.20079.23341, Git hash:master @ 064283610b834170e52117f2656605b5b25d65c0)
License type: Evaluation, build 2020-03-19
License details: Cloud Zoo. In use by: sam ()
Expires on: 2020-07-20
Windows 10.0 SR0.0 or greater (Physical RAM: 7.5Gb)
Machine name: WINDOWS-CMIP96S
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA Quadro M1000M (NVidia) Memory: 2GB, Driver date: 1-31-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 442.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-31-2020
Driver Version: 26.21.14.4223
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.24.20079.23341
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.24.20079.23341
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.24.20079.23341
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.24.20079.23341
Many thanks.
I have tried the raytrace and does work quicker. From task manager I see that in raytrace mode it used the GPU and in render it uses the CPU.
Do you know if its possible to set the rednder to use GPU same as raytrace?
wim
(Wim Dekeyser)
April 22, 2020, 11:53am
6
Hi - not on Rhino 6, no. And, IIRC, on the Rhino 7 WIP it still depends on which OS and GPU you have…
