Is it possible to render a SubD object in its Base Geometry form?
Thanks
Hi @user1903
If you mean box mode, yes. You just extract the control polygon and render that instead (ExtractControlPolygon
, not surprisingly).
HTH, Jakob
Thanks.
After I did that, I had trouble finding the button. Then I saw the “Subset” choices on the Mesh Tools sidebar.
I’m learning every time I play with Rhino … with the help from you people.
When I type a command in the command line, is there a way to find the corresponding button to add to one of the Main toolbars (I know how to add a button)?
So I create a blank button and then follow your steps?
Yes - you can right click in an empty bit of a toolbar and choose ‘New Button’
Fill in something for the Command and give it an icon by clicking Edit by the square in the top right.
